conditional equation for evidence
bahman
Post by bahman »
HI Marek;
in this image i need to C*=dt when there is no any evidence for node Z (i mean igonore node C* ) and if node Z have evidence z_1 then node C*=exp(1)
iF
evidence in node Z is set to Z_1 state
then C*=EXP(1)
ELSE
C*=node dt (Identity Matrix conditioan on dt)
END
when there is no any evidence for node Z; it should be C*=dt and i think p( C*| z_1 , dt) is true but for p( C*| z_0 , dt) it should be a Identity Matrix in discretization table but is not
i tied this equation for C*
Node2=If(ZD="z_1",Exponential(1),If(ZD="z_0",dt,dt))
AND
Node2=If(ZD="z_1",Exponential(1),dt)
both of them have same output .i need a equation that exactly do this only when i have seted an evidence for node Z
can you suggest another equation for this ?
thank you
Re: conditional equation for evidence
Hi Bahman,
I hope I understand the question correctly. My understanding is that C has two parents, dt and Z. Also, there are possibly multiple outcomes of ZD, of which one is "z_1". In that case, your definition of C should be something like:
C = If(ZD="z_1",Exponential(1),dt)
If ZD takes the value z_1, C will have a value that is a sample from Exponential, otherwise the value of the variable dt. Please note that this may be not precisely what you wrote. It is impossible to refer in the definition to whether a node is observed or not. This would be part of the result. You should be able to achieve what you want by a smart definition.
I hope this helps.
