Value Tab in final node
There is a guidance to analyze the operation of value tab in a final variable node for example, there is 1000 sampling running and the values of kurtosis, standard deviation and max value, i know is obvious, but it should analyze the operation process somewhere (why there is 1000 sampling, what Probability distribution means each statistical data in the value tab. for example (kyrtosis: ###, std deviation:###< max value: ##) the meaning about the probability to have each state in our final node?
Re: Value Tab in final node
Hi Viliop,
I will be glad to help but please help me to understand your question. Are you referring to hybrid networks and a continuous node in such a network? What do you mean by a "final variable node"? A node with no successors? The number of samples can be set in Network Properties, Sampling tab.
