.NET - Visual Studio 2008 (C#)
jeffs
Post by jeffs »
When trying to create a .NET (C#) application, I ran into trouble from the first line of code.
It makes me ask whether anyone has tried this with VisualStudio 2008 and the .NET 3.5 SP1 framework.
A very simple app - I added a button to mainform.
Inside the event handler:
Network = new Smile.Network();
The application terminates immediately with this error:
BadImageFormatException was unhandled
is not a valid Win32 application. (Exception from HRESULT: 0x800700C1)
The output window shows:
'BayesSmile.vshost.exe' (Managed): Loaded 'C:\Development\Playground\C#\BayesSmile\BayesSmile\bin\Debug\BayesSmile.exe', Symbols loaded.
A first chance exception of type 'System.BadImageFormatException' occurred in System.Windows.Forms.dll
'BayesSmile.vshost.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
Has anyone used the .NET wrapper for Smile with C#?
If so, what about with VS 2008 and .NET Framework 3.5 SP1?
Re: .NET - Visual Studio 2008 (C#)
Yes, we test SmileNet with C#.
I've just made simple Winforms app with VS 2008 and .NET 3.5 (no SP1, however), it works just fine. Note that your exception occurs in System.Windows.Forms.dll - maybe some of your binaries are corrupt.
You may try to remove the call to SmileNet to check if problem persists.
jeffs
Post by jeffs »
If I comment out the single line that creates a Smile.Network object, then the app runs just fine (there's almost nothing in it).
So I'm thinking that the .dll file is corrupt. The dll was contained inside a zip file downloaded 2 days ago from the Genie website., which I downloaded inside a zip file.
What version of the .NET framework and VisualStudio did you try this with? I am building on Vista64, VS2008 SP1. and .NET 3.5. I did try with .NET 2.0 and .NET 3.0 with similar results.
Thanks for any help you can provide.
jeffs wrote:What version of the .NET framework and VisualStudio did you try this with? I am building on Vista64, VS2008 SP1. and .NET 3.5.
I've tested with VS2008 SP1 with .NET 2.0 and 3.5 on Vista 32-bit, using the Smile.NET binaries available at our website. Smilenet.dll file size should be 1,265,664 bytes.
jeffs
Post by jeffs »
I have the same .dll size.
And the object browser and intellisense all work to show the various classes and methods within the Smile.NET assembly.
I'm at a loss as to what might be causing the crash.
jeffs wrote:I'm at a loss as to what might be causing the crash.
I'm also running out of ideas. Can you search for all occurences of smilenet.dll on your harddrive, delete them and re-download the file?
jeffs
Post by jeffs »
This should have been obvious to me earlier.
I'm building a .NET app on Vist 64, which I think will build a true 64 bit application (regardless of the .NET language).
The smilenet.dll is a 32 bit compiled DLL, and the application dies when it tries to load the library.
I tried the same C# application build on XP 32 just now and it works fine.
So, do you have a 64 bit .dll available for SmileNET? I tried to build the project from source but got extensive warnings about unmanaged directives no longer supported and a few errors.
With Windows7 on the way I think you'll be seeing a lot more 64 bit usage with .NET.
jeffs
Post by jeffs »
This is now resolved. Here is what I learned:
For Vista/64 bit platforms:
If you want to build a .NET application (for example in C#) you must explicitly configure the build for the x86 platform. If you choose "Any CPU" on a 64 bit platform, then you get a 64 bit application trying to load a 32 bit .dll, the Smile.NET assembly.
(These instructions are relevant to Visual Studio 2008)
To configure you build, from the menu:
Build->Configuration Manager.
Click on the dropdown labeled "Active Solution Platform"
Click <New..>
Specify the x86 platform.
Of course, you also need to add reference to the smilenet.dll file in your project:
Project->Add Reference...
Click the "Browse" tab
Find your .dll file and click OK.
