I'm looking for a way to visualize the workings of my network in realtime (while it's being "manipulated" with jSMILE).
Before I start to make something on my own, I thought I check back here first, maybe I'm not the first who needs something like this.
I don't suppose there is a way to update the visualization of the network within a running Genie instance through an API?
Thanks for any input on this issue!
Graphical Output for SMILE
Re: Graphical Output for SMILE
what does it mean ?I'm looking for a way to visualize the workings of my network in realtime (while it's being "manipulated" with jSMILE).
Ok, I probably could have worded this better, hopefully this example is better:Gardiola wrote:what does it mean ?I'm looking for a way to visualize the workings of my network in realtime (while it's being "manipulated" with jSMILE).
I have an application that reads values from a sensor. Based on the sensor data, I enter certain evidences into the network with jSMILE, update the beliefs, read the output from a certain node and then the application makes a certain decision based on that.
When a user normally interacts with this application, the only thing he sees are the effects of the decisions, but not the inner workings of the network. A next step would of course be to print information such as "evidence X set", "probability of X is now Y" etc. to a console.
However I would like to have a graphical output / trace of what is happening in the network. Again, what I can do is create a new case for each taken decision and then later on view them in Genie's case manager, but that is not in realtime.
No, GeNIe does not expose any functionality to 3rd party code.HoloDoc wrote:I don't suppose there is a way to update the visualization of the network within a running Genie instance through an API?
