SMILE cannot create a network, error -42
BayesFusionUser123
Post by BayesFusionUser123 »
I got an error when creating a network using the code below:
from functools import partial
import pysmile
import pysmile_license
def create_cpt_node(net, id, name, outcomes, x_pos, y_pos):
    handle = net.add_node(pysmile.NodeType.CPT, id)
    net.set_node_name(handle, name)
    net.set_node_position(handle, x_pos, y_pos, 85, 55)
    initial_outcome_count = net.get_outcome_count(handle)
    for i in range(0, initial_outcome_count):
        net.set_outcome_id(handle, i, outcomes[i])
    for i in range(initial_outcome_count, len(outcomes)):
        net.add_outcome(handle, outcomes[i])
    return handle
def construct_SMILE_network_with_n_parents(n_parents):
    Construct SMILE predefined network and save it to output folder
    Build a causal DAG:
    P_1 -> T -> O
    P_2 -> T -> O
    P_n -> T -> O
    var_unique_val_dict = {}
    var_unique_val_dict["T"] = ["T___1", "T___0"]
    var_unique_val_dict["O"] = ["O___1", "O___0"]
    for i in range(n_parents):
        var_unique_val_dict[f"P_{i + 1}"] = [f"P_{i + 1}___1", f"P_{i + 1}___0"]
    #endfor
    predefined_hybrid_net = pysmile.Network()
    # (1) add all nodes properly
    x = 10
    var_to_val_list_dict = {}
    for var_name in var_unique_val_dict.keys():
        #print(var_name)
        var_val_list = var_unique_val_dict[var_name]
        var_to_val_list_dict[var_name] = var_val_list
        create_cpt_node(predefined_hybrid_net, var_name, var_name, var_val_list, 10, x)
        x += 10
    #endfor
    print("SMILE var_to_val_list_dict:")
    for var_n, var_val_list in var_to_val_list_dict.items():
        print(f"{var_n}: {var_val_list}")
    #endfor
    # (2)
        parent = f"P_{i+1}"
        predefined_hybrid_net.add_arc(parent, "T")
        print(f"method-[construct_SMILE_network_with_n_parents] add_arc: {parent} -> T")
    #endfor
    predefined_hybrid_net.add_arc('T', "O")
    return predefined_hybrid_net
SMILE_net = construct_SMILE_network_with_n_parents(37)
The error message is like below:
Traceback (most recent call last):
  File "20260430_SMILE_network_creation_error_-42.py", line 75, in <module>
  File "20260430_SMILE_network_creation_error_-42.py", line 67, in construct_SMILE_network_with_n_parents
pysmile.SMILEException: SMILE Error -42 in function Network.AddArc
Could you please tell me the reason of this error, how to correct it and what does error -42 mean?
Thanks.
Re: SMILE cannot create a network, error -42
Error code -42 indicates an out-of-memory exception caught by SMILE. In your case, it's most likely at add_arc call used to connect P_{i+1} and T.
In SMILE, the single CPT can have 2^31 elements - with all binary nodes this would be a node with 30 parents.
BayesFusionUser123
"In SMILE, the single CPT can have 2^31 elements - with all binary nodes this would be a node with 30 parents."
Is this a hard limit, OR is it possible to extend this limit somehow?
This is the hard limit for the CPT representation.
You can have more than 31 parents if you use NoisyMAX nodes instead of CPT nodes, and enabled NoisyMAX decomposition in network properties.
For more information, refer to SMILE Wrappers Manual chapter "Noisy-MAX decomposition", in the PDF version chapter number is 6.6.2.
