Genie has problems with big nets
Christian
Post by Christian »
if I build a network with more than average 25 million values I can calculate, edit all the values and so on. But as soon as I want to save this net, GeNIe is crashing.
So it seems that smile is ok with that big networks, but GeNIe not?
Re: Genie has problems with big nets
Can you describe the configuration of the network, so I can try to reproduce the problem?
Christian
Post by Christian »
sorry for my late answer, I was out of town lately. I have build an example for you.
To reproduce the error, do the following:
1) Open the network
2) Connect Node6 to Node 1.
3) Press F5 to calculate. This should work fine every time.
4) Press Save As and save the network.
Most of the time GeNIe crashes now. If it does not crash I am unable to load the network from that file.
If you need a much more sure crashing situation, just enter some more states in Node6 between 1) and 2).
Using these large networks, GeNIe can caluclate them, but not save/load them. My guess is, that the error is a result as soon as GeNIe uses more than 700MB to save. But for calculation GeNIe does not use that amount of memory as it seems.
crashing_network.zip
(152.42 KiB) Downloaded 2208 times
Thanks for the bug report. I was able to reproduce the problem on my machine. The problem is caused by very large size of CPT in Node1. The XDSL writer converts each node probability table to string representation before writing it to disk. In this case, there's not enough memory used for actual CPT and the temporary string. The solution of course is to write directly to the file.
Unfortunately, I can't give you the estimate for the bugfix now; this is not a trivial change, especially on the parser side. Stay tuned.
I have modified the XDSL writer and parser to handle your network. The changes were extensive, so I need more time to test it thoroughly. New binaries should be available in the first week of 2008.
shooltz wrote:New binaries should be available in the first week of 2008.
Let's call it first _full_ week of 2008. But they're coming :)
Christian
Post by Christian »
:D
It's okay, it is done when it is done :D
I can wait. So take the time you need. Hey, it is a free software, so everything I get and every response of you and Marc is a bounty.
I have working/tested GeNIe and SMILE now. However, since the changes in the XDSL parser were extensive, I plan to test it for one or two more days.
Send me a private message if you'd like to download binaries before they go final/public.
GeNIe 2.0.2932.0 is ready for download.
Christian
Post by Christian »
thank you very much, I will give it a try.
